Originally Posted by sqidd
How about notching and channeling the floor so you can run it on the underside but still have ground clearance?
This kinda what I decided on. I got the second flex pipe installed and welded today. I also mounted and welded in the boost control e-cut out valve.
Now the hardest part is next, running the 3" exhaust pipe from the O2 housing to the outside of the car.
![EEK!](/forum/images/smilies/eek.gif)
Then once that done I can run the 2" bi-pass muffler system around the e-cut out valve.
Then run the oil feed and oil return lines.
