not sure how to tell if parts are interchangeable.
wow! is that 2 plugs per cylinder? that's one way to adjust timing for lean burn!
is the insight/fit motor still a "d" series motor? I know you can make some pretty wild combinations between all the "d" series stuff. that would be wild if you put one into an insight!
