Old 10-13-2014, 10:46 AM   #94 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by sqidd View Post
IDK what is up with that goofy pump in that kit. Never heard of it, and I do a LOT of R&D/testing on A2W IC pumps. Chances are if it was any good I would know all about it.
What size are the AN fittings on that core? That is CRITICAL! That will make or break a A2W system. I'm not kidding hear, that is very, very important. I wouldn't go with anything under a -16. -20 would be ideal.
If you are only going to use it at the drags or hillclimbs don't mess with a heat exchanger. You will have to run a LOT more exchanger than that to get the performance you want. Plus you are going to have to mount and plumb that sucker somewhere that gets a lot of airflow. For what you are doing I would run a ice chest. It will work about elenvindy billion times better and end up costing you less money in the end because when you are running an ice chest you can employ one of the lower cost bilge pumps. And you can mount the ice chest in the back of the car out of sight and where you have more room. And if you need to you can always run it with just water in it. If the ice chest is aluminum it will shed quite a bit of heat.
Thanks again for the info. It looks like it has 3/4" NPT or around a 12AN fitting so I will have to go bigger? You sound like you have done this a couple times so any suggestions on which one to go with would be great!
You answered my question about the heat exchanger plus I'm starting to run out of room as it sits already. I love the idea of running a ice chest as you suggested. This will be the direction I will go.
Pressure Gradient Force
The Positive Side of the Number Line
