Old 10-13-2014, 12:00 PM   #95 (permalink)
sqidd
Uber Geek
sqidd's Avatar
Mr. Scary - '07 Ford Mustang GT Race Car
The Truck - '12 Ford F-150 Scab EcoBoost FX4
The 5.0 - '12 Ford Mustang GT Vert Brembo Premium
Da Foci - '14 Ford Focus SE
Originally Posted by pgfpro View Post
Thanks again for the info. It looks like it has 3/4" NPT or around a 12AN fitting so I will have to go bigger? You sound like you have done this a couple times so any suggestions on which one to go with would be great!
Yeah, more than a few times. I've done so much testing that a couple of the pump companies call me for info, LOL!
-12 is dismal. It is common, but dismal. The only way to get -12 to work the way you are going to need it to will require the use of the Lingenfelter super duper boom diggidy pump (it's a hot roded Steward Warner pump) that costs about $600 and pulls a TON of amps. With that pump you will move about 9.5gpm (gallons/minute).Which is decent, but nothing to write home about.
If you run any of the other pumps out there at -12 you will be looking at about 6.5-7.5gpm.
If you run -16 you can move about 15gpm with a $100 Rule 2000 bilge pump.
If you run -20 you can get a little over 20gpm with the next size up Rule 3700 bilge pump. They are about $175.
Line/fitting size is the key.
What sort of boost will that A2W IC see?
The Following User Says Thank You to sqidd For This Useful Post:
pgfpro (10-13-2014)
