Originally Posted by pgfpro
That helps me a lot!!! Thanks!!!
Max boost on the LP turbo and A2W will be 32psi.
32psi is going to be about 425deg! Which is not screwing around one bit. I've seen cars with IC's about the same as yours VAPORIZE the water at 275deg with a 6gpm water flow!
VAPORIZE! Not good. The solution is to move the water though the IC faster. At 32psi you are going to want at least 15gpm.
