Old 10-14-2014, 06:13 PM   #82 (permalink)
IsaacCarlson
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
A hot brake indicates the beginning of a stuck caliper. Brake fluid absorbs water. This will form a rusty deposit in the bottom of the caliper cylinder as the piston moves out as the pads wear. When you put new brake pads in and push the piston back into the cylinder, it will ride over this deposit and stick. It may not be noticeable at first, but they will begin to drag as the piston binds in the cylinder. An older caliper can seize as the deposits work under the piston and fuse it to the cylinder. It is very important to remove the piston from the cylinder when replacing brake pads to ensure the cylinder is clean. Brake fluid should be flushed yearly as should power steering fluid. If your fluid looks dirty, it is. It should be clear or amber colored.
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
The Following 3 Users Say Thank You to IsaacCarlson For This Useful Post:
101Volts (06-13-2017), j12piprius (10-14-2014), Piwoslaw (05-14-2022)
