Old 10-17-2014, 03:58 PM   #22 (permalink)
freebeard
NewMPGfrontier -- I'm not surprised you're having problems. Follow the link to the Dropbox page and the normal right-click options are unavailable, replaced with their own choice, Download Original. I downloaded one twice, reloaded the page and the '?dl=0' in the page's URL hadn't incremented. Try putting the images in an album on you Profile page.
That said, here's a comment on your work so far. You have a 2" step all around the back of the cab. That's your separation point. The wedge would be only a wake filler.
If the frame was moved out flush with the contour of the cab (with a recess for the third brake light), then the tight radius between the top and side would become a problem. With the taperless plan, vortexes will roll up and over onto the top. Without flushing out the transition, that would aid reattachment on the top, but it won't help the sides.
Given the material you're working with you could start the top tangent to the cab and then curve it downward, instead of the flat wedge shape.
slowmover -- I always appreciate the perspective you provide.
slowmover (10-18-2014)
