Thanks Paul,
Tried t-fault-rc 5
No difference.
I measured the voltage between pin 5 (5V) where i have the red throttle wire, and pin 4 (throttle input) where I have the white wire. It reads 5v at zero throttle and 0 volts at full throttle. However the RTDexplorer graph displays correctly.
Shouldn't the throttle go from 0 to 5?
Are the wires connected wrong or did the firmware update somehow go wrong?
Edit: no, I guess that correct. Voltage difference between input and 5v is 5v when the input is 0v at 0 throttle. At full throttle the difference is 0v. Right?
