Old 10-20-2014, 08:17 PM   #30 (permalink)
H-Man
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
http://bgbonline.celicatech.com/6g/t...05%20speed.pdf
The C52 gearbox rebuild
http://discodan.org/gfx/celica/servi.../chassis/a.pdf
Found those searching for 'C52 bearing preload'
My ae92 FSM outlines a similar procedure I think. For torquing, you need an in*lb torque wrench or maybe a spring scale and a wrench with a hole drilled in the handle an inch away from the center of the box end.
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
The Following User Says Thank You to H-Man For This Useful Post:
Daox (10-20-2014)
