Old 10-22-2014, 10:20 AM   #249 (permalink)
wyatt
Big Salsa - '04 Toyota Sienna LE
Silver - '10 Toyota Prius III
Originally Posted by aardvarcus View Post
Also, you will probably want to make sure that at the normal resting position on flat ground the shock is roughly in the middle of it's travel. That way the shocks won't over extend/compress if you drive over a sharp change in slope on the road.
How do you compress the shock to it's midpoint so you can attach it to your vehicle?
The Following User Says Thank You to wyatt For This Useful Post:
BamZipPow (10-22-2014)
