Bump starting is easy. Just slide it in gear and smoothly let off the clutch pedal, just like you do when you shift gears. When it catches, quickly push the pedal back in and it should be running. Then put it in the appropriate gear and let off the pedal again.
I only coast in gear if the hill is steep enough that I need brakes to maintain a safe speed. Otherwise it is neutral and typically engine off.
