Old 10-22-2014, 10:14 PM   #22 (permalink)
Ecky
90 day: 39.06 mpg (US)
Work Vehicle - '17 Toyota RAV4
90 day: 33.13 mpg (US)
For those other G1 Insight owners out there, staying in lean burn is based on throttle position...
Fantastic idea. $100 is more than I'd like to spend on this kind of mod but it's cheaper than aftermarket cruise control. I'll probably play with low-rate springs for a bit and see if I run into what you did.
EDIT: A 2-stage mechanism would be ideal for the Insight. The upper one would be best as a tactile-feedback (a click), with your resistance setup for the lower one.
