Originally Posted by Astro
If you disconnect the speedo cable from the gearbox can you see if the sleeve with the slot in it (gearbox side) turns when the wheels are turning?
I should be able to do that tomorrow
Another thought, I have never tried this, but could you use a cordless drill on low speed to turn the inner part of the speedo cable (cable side) to see if that gets the needle moving?
There is a pin on the speedometer that fits into a slot in the gearbox. I think that would be damaged by using a cordless drill.
Perhaps just taking it apart will show a problem. I read several warnings about taking it apart carefully to avoid damage .. perhaps I was not careful enough?
