Old 10-28-2014, 03:53 PM   #5 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 59.95 mpg (US)
Originally Posted by cannabinoid View Post
Thanks man I did see that late last night, do I need the tranny though?
Also I thought I could not use a d15z1 since its a 16 valve while mine is an 8 valve, also what about the whole vtec connection, i believe mine is SOHC.
The number of valves inside the engine will not affect how it mounts or runs in your engine bay, the difficulty will be in the wiring. D15Z1 is an amazing engine but getting the wiring right will be a nightmare.
VTEC is a solenoid-operated mechanism that changes the valve lift, which allows for an engine to be optimized for both low- and high-RPM. It's typically not included in the cheaper engines.
All D-series engines are SOHC.
I agree with Balto's suggestion. If you replace it with the same engine, you won't have to change the ECU out or mess with any wiring. A spare transmission is nice to have, and you could always sell it.
