Old 10-29-2014, 11:41 AM   #121 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
dustyfirewalker
A great way to chose a turbo compressor and turbine size especially if your going BW is use their "Match Bot" program.
Performance Turbos | BorgWarner Turbo Systems
Check out their tutorial's for what does what.
You can even get creative by seeing what a draw through set up would do to the compressor map plots by changing the altitude to a higher number.
Pressure Gradient Force
The Positive Side of the Number Line
The Following User Says Thank You to pgfpro For This Useful Post:
dustyfirewalker (10-29-2014)
