Old 10-29-2014, 03:45 PM   #271 (permalink)
COcyclist
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 52.55 mpg (US)
Just curious, what pressure are you running in the trailer tire? Is the oscillation less pronounced with a load? My father used to run some pretty low tire pressure in his trailer to cut down on the bouncing, with light loads. We had an old Sears one wheel trailer that he used for many years and thousands of miles.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following User Says Thank You to COcyclist For This Useful Post:
BamZipPow (10-29-2014)
