Old 10-29-2014, 03:13 PM   #6 (permalink)
redpoint5
Lafawnda - '01 Honda CBR600 F4i
Big Yeller - '98 Dodge Ram 2500 base
Prius Plug-in - '12 Toyota Prius Plug-in
90 day: 57.64 mpg (US)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 23.6 mpg (US)
Originally Posted by OG VX View Post
Bump! Hoping for pics and/or more details about using the OEM rear defroster and/or cruise control switch (I understand that they are, essentially, the same switch design; not confirmed though) as a panel mounted, OEM-looking, kill switch.
Can anyone provide details (with wire colors, if possible) about where to run each wire from a factor 92-95 VX rear defroster switch, with a connector/pig tail cut from a junk yard?
If possible, I'm hoping for the switch to be illuminated, but it's not a must.
Thanks!
I doubt there were factory illuminated switches for cruise or defrost for the car you're looking at.
The best bet is to buy an illuminated momentary switch and wire it into a blank switch plate on your car.
I'll probably buy something like this when I figure out how to kill my engine.
