Old 10-30-2014, 04:02 PM   #16 (permalink)
darcane
darcane's Avatar
Originally Posted by S Keith View Post
Let's assume 7% is a real number. Let's use easy math and say the propulsive efficiency jumps from 20% to 27%. That's a huge change, which draws the 7% claim into question, and it's nearly 30%, which is where I suspect the 30% emissions number comes from, but we're still only only utilizing 27% of the heat energy burned vs. 80% with regular oil.
"Easy math" often means you are doing it wrong.
You need to pay attention when working with percentages. A 7% increase of 20% is not 27% but 21.4% (Multiply by 1.07 not add 7%).
If the claims are close to accurate for emissions and wear, it's because of improved warm-up times as Ecky stated. However, just one high RPM romp with 300°F oil could easily negate all reduction in wear...
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
The Following 3 Users Say Thank You to darcane For This Useful Post:
Sven7 (10-31-2014), user removed (10-30-2014), Xist (10-30-2014)
