Originally Posted by BamZipPow
 [/URL]
I did check the tire pressure and it was 35psi. I'll give the air bag a shot first before I think about lowering the tire air pressure. Doesn't the tire heat up and fail prematurely when under-inflated based on a heavy load?
Hmmm. Our trailer had coil spring suspension. That may be part of the problem. Perhaps the air suspension may help. I agree, 35 psi is minimum with a load on.
