Old 10-31-2014, 01:18 PM   #1 (permalink)
Daox
How To: Alternator delete
I have recently found out that the battery in my Metro doesn't have a ton of life left in it. Being an ecomodder, I instantly think this is a great time to do an alternator delete mod. So, I figured I'd go through the steps of figuring out how to actually do an alternator delete for anyone who doesn't know already.
Step one is to figure out how much power your car uses so you can size your battery correctly. This is probably the trickiest part to do. The best way to do this is to measure your electrical power consumption with an ammeter. However, for those who don't have an ammeter, Darin posted a great thread on electrical loads a while back which I'm quoting below. Its a pretty comprehensive list, and your car likely doesn't have all these goodies. The Metro sure doesn't. However, you do want to calculate a worst case scenario to size your battery so you know you have enough power no matter what. If you compromise on battery capacity, you'll have to keep that in mind as you drive daily.
Code:
Engine Management            Power (W)
Fuel Pumps Injectors         135
Ignition System              60
Electronic Throttle Sys.     60
Sensors a Actuators          110
Solenoids & Relays           20
Subtotal Engine              385
Amps @ 14.2V                 27.11
 Chassis Electrification      Power (W)
Electric assist steering     300
ABS brake system             200
Air suspension valves        50
Air compressor               500
Subtotal Chassis             1050
Amps @ 14.2V                 73.94
 Charging System              Power (W)
Alternator                   3000
Battery (80 Ah)              1000
Starter motor                2200
 Multimedia & HVAC            Power (W)
High end audio sys.          300
Navigation and GPS           150
Driver information display   30
Cabin climate valves         75
Blower motor + ECU           370
Subtotal Cabin Sys.          925
Amps @ 14.2V                 65.14
 Lighting (Exterior & Interior) Power (W)
Headlamps (2)                120
Running/Park lights (4)      130
Turn signal lamps            130
Center high mount stop        65
Back-up, interior, license    45
Subtotal lighting            490
Amps @ 14.2V                 34.51
 Body Electrical              Power(W)
Power Windows (4)            560
Power Door Locks (4)         200
Wipers and washers           140
Heated backlight             500
Power seats (2)              460
Subtotal Body Sys.           1860
Amps @ 14.2V                 130.99
 Future Systems              Power(W)
DVD and in-seat displays
MicroJMild-hybrid functions
Active suspension
Frontyrear radar
Obstacle detection & Airbags
Active cruise control
Total Electrical/Electronics    4710
For my specific case, I know the exact electrical loads thanks to Darin and others on this forum. Here is an exact list of electrical loads for the Metro.
So, for my example lets add them up to get a worst case. My worst case scenario is a winter commute of ~15 miles per day. This equates to roughly 30 minutes of driving. Obviously the engine must be running for some of this, and the engine pulls roughly 140W or 10A. Since its winter, I want heat, so my fan will be on some of the time. I'll use fan setting 3/4 for 140W or 10A. Its also dark out, so my lights will be on which uses 240W or 20A. The total for these loads is 40A.
This means I'm using 40A for 30 minutes. Battery capacity is rated in amp hours (Ah). So, if I use 40 amps for a half hour, I've used 20 Ah. This would be just enough power to get me to work and back under a typical bad weather scenario. However, I do take the occasional trip that is longer than 15 minutes, and what if I want to run some errands after work? Well, we need more capacity.
In my case, I don't use the Metro for long hauls. But, I go to occasional lunch meeting and what not. So, I would like to aim for 1-1.5 hours of run time. Using the above calculation, for 1.5 hours of run time at 40A, I need 60Ah of battery capacity.
So, I need 60Ah of usable battery capacity. If I go with lead acid (which I probably will), the rule of thumb for optimum battery life is to not exceed 50% depth of discharge (DOD). This means don't discharge the battery beyond half of its capacity. Now, for 60Ah of usable capacity, I need a 120Ah battery. This is what I should be aiming for. Quite a far cry from the 20Ah I initially calculated.
If you wanted to get fancy and go with lithium, their rule of thumb for DOD is 70-80%. This means you'll only need a 80-90Ah battery.
Sizing the battery in this manner will ensure that you have enough power to get around without the alternator without worrying about it, and it will also ensure that your battery will live a long happy life without you abusing it.
So, that is step one.
A 120Ah battery is fairly large, so we'll see what I can actually fit into the engine bay of the Metro. I may compromise and drop down to a smaller battery and just use the alternator for those longer trips, then turn it off on the way home.
The Following 7 Users Say Thank You to Daox For This Useful Post:
BabyDiesel (10-31-2014), jedi_sol (10-31-2014), MetroMPG (10-31-2014), mikeyjd (04-15-2015), pletby (10-31-2014), The donkey CRX (10-31-2014), Xist (11-01-2014)
