Picked up the shop manual today, which gives me the roadmap for wiring the trike. I could not read the color codes off of anything I could find on the web, or on the attachment Sendler was kind enough to send me.
I may have to change the rear wheel from a 17 inch to a 16 inch. The overall tire diameter can not exceed 28 inches and the rim is only 5 inches wide. I may just get the machine shop to use the existing wheel and an aluminum rim (15X5) to make a rear wheel that uses the same tire as the fronts which I also already have.
Another welding session next week.
regards
mech
