Old 11-01-2014, 06:57 AM   #355 (permalink)
sendler
sendler's Avatar
90 day: 105.14 mpg (US)
90 day: 60.68 mpg (US)
90 day: 38.51 mpg (US)
PCX153 - '13 Honda PCX150
90 day: 104.48 mpg (US)
90 day: 80.94 mpg (US)
90 day: 72.57 mpg (US)
Having a tire diameter/ circumference that is slightly larger than stock (24.7") is an easy way to gain some longer gearing. Going out to the full 28" is only a 13% increase in final gearing which is about the minimum increase that you will want. 15/ 36 sprockets give 16% longer gearing with the stock tire and I may go to a 35, which is the smallest that can fit, when my 36 wears out. The most efficient highway cruise rpm is under 6,000. With 15/ 36 I get 68mph at 6,000.
