Old 11-03-2014, 05:36 PM   #21 (permalink)
RedDevil
90 day: 56.29 mpg (US)
The NiMH batteries they used at first degrade relatively quickly if you keep charging and discharging them fully on a regular basis.
That's why the plug-in Prius uses lithium.
They did not change their mind, they changed the chemistry.
one advantage of the 2nd gen Insight is the lower voltage on the pack; see http://avt.inel.gov/pdf/hev/batteryinsight1748.pdf.
A parallel pack of about 117 Volt would do, no DC-DC conversion needed just 36 LiFePO4 cells in series.
That could be split into 3 '36V' packs or 9 '12V' subpacks and have standard 36V or 12V chargers per subpack.
Using lithium, 32 cells would do too, which can be split into any power of 2 sized number of subpacks.
