For rigidity, I suggest
1) screw or tape everything down to make the plastic hold its shape.
2) Line the back side with 2 layers of fiberglass and resin. I that should allow the whole cover to retain its shape and add rigidity.
Since you'll be doing the backside, no need to worry about "finishing" with sanding and bondo.
