Old 11-05-2014, 03:51 PM   #49 (permalink)
bmack2
Thanks so much with the design help! My buddy is installing the outlet for my welder this weekend, so should be well on my way in the next few weeks. I checked out the 3/4 inch angle iron last night and decided it is more than strong enough.
Bob, I am just curious about how you latch the wedge shut, I tried to look closely at the pictures, from what I can tell its just a hole in the 3X3 and in the wedge in which you put a pin through it? And is there a specific type of hinge you feel I should use for the top or would a regular door hinge work from home depot. I checked grainger but cant seem to find what fits your description.
We shall see how this model works and maybe in the future I will weld one up in aluminum and add in smooth edges, however can not afford that at the moment money and time wise. Surplus steel is pretty much the most I can afford.
