Of course, if the fuel is heated it will evaporate slightly easier so it will burn cleaner in a cold engine.
Only problem is that when the engine is cold, so is the coolant and hence the fuel...
It will help. A bit. Even though they name it a fuel converter instead of preheater and charge 10 times what it is worth.
I don't call my HIDs luminosity boosters, my grill block an airflow optimizer or my LEDs candescenses. Though I might in the future
