Old 11-08-2014, 02:25 PM   #13 (permalink)
Daox
I pulled things apart and I was off one tooth on the timing. I reassembled things and fixed the ELD sensor in the car. Then it started having other issues:
Now, it won't start on its own, you have to give it some gas to get it to start. Then, you get the flashing engine light due to misfires. Eventually, I get a P0303, P0304, and P0300.
So, I pulled the plugs and 3 & 4 look normal to me, but 1 & 2 look super rich. Swapped the ignition coils around, no difference.
1, 2, 3, and 4 left to right.
So, next up I checked the resistance of the fuel injectors. Each one is dead on 15 ohms.
So, I'm quite confused... Any ideas guys?
