Old 11-08-2014, 03:30 PM   #10 (permalink)
jedi_sol
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
Would resin attach the foam to the plastic well or should I use something else? I could definitely fiberglass the foam, although I would need to sand it down first, and I doubt that would be easy to do evenly.
yes and no
the resin might detach from the plastic over time since the plastic is smooth, therefore, the resin won't "grip". You can help adhesion by sanding the plastic a bit before applying resin. This should give the resin a little more "grip" to hold onto the plastic. Then to be more secure, screw down the plastic onto the fiberglass/foam
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
The Following User Says Thank You to jedi_sol For This Useful Post:
Xist (11-08-2014)
