Old 11-08-2014, 07:07 PM   #5 (permalink)
Xist
That is just the type of crazy story I expect to find on-line.
Hey guys! Look what I found!
From http://en.wikipedia.org/wiki/Soybean_Car:
The Soybean car, more recently referred to as the Hemp body car, was a car build with agricultural plastic. Although the formula used to create the plasticized panels has been lost, it is conjectured that the first iteration of the body was made partially from soybeans and Hemp. The body was lighter and therefore more fuel efficient than a normal metal body. It was made by Henry Ford's auto company in Dearborn, Michigan, through the work of scientist/botanist George Washington Carver and was introduced to public view on August 13, 1941.
How do you change "build" to "built?"
Because of World War II all US automobile production was curtailed considerably, and the plastic car experiment basically came to a halt. By the end of the war the plastic car idea went into oblivion. According to Lowell Overly, the prototype car was destroyed by Bob Gregorie.
Ford wished to make his new plastic material a replacement for the metals used in normal cars. A side benefit would have been easing of the shortage of metal during World War II.
I guess that it did not ease the shortage enough.
The frame of this automobile was made of tubular steel, to which were attached some fourteen plastic panels, said to be "only a quarter of an inch (6 mm) thick." The windows were made of acrylic sheets. All of this led to a reduction in weight from 2500 pounds for a typical car to 1900 pounds, a reduction in weight of about 25 per cent.
Lowell Overly, the person who had the most influence in creating the car, says it was "...soybean fiber in a phenolic resin with formaldehyde used in the impregnation."
A report circulating on the Internet shows a film from 1941 about the plastic car in the opening credits as being the plastic soybean car, but at the end part it shows images of Henry Ford striking a hammer or axe onto a trunk lid. It is not the Soybean Car he is hitting, but Ford's personal car with a plastic panel of the same material on the trunk, and the hammer had a rubber boot placed on the sharp end of the ax.
"Why use up the forests which were centuries in the making and the mines which required ages to lay down, if we can get the equivalent of forest and mineral products in the annual growth of the (hemp) fields?"—Henry Ford
