Old 11-08-2014, 08:30 PM   #17 (permalink)
ksa8907
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
It ran just fine before the headgasket. I just had it apart and verified the timing is correct.
Its possible a sensor is bad, but I'm not getting an engine light for it. I'd assume that it would throw a code if that were the case.
If the timing is good and you're confident the headgasket was done correctly, it boils down to electrical. I agree with old mech on this one. Probably a gremlin in there somewhere. Check all connectors that were removed during the repairs, use contact cleaner if you have it.
