Old 11-11-2014, 02:48 PM   #290 (permalink)
BamZipPow
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Wink
The trailer body is framed out!
I still have to build out the bottom frame work fer the trailer belly pan. I did drop the back end of the belly pan about 1.5" so the angle wouldn't be as fast as it was before.
I've figured that the diameter of the swivel is about 36". Still working on how to support the frame work fer that part. Definitely thinking of using foam so it won't add a lot of mass to the swivel. I just hope it will survive the vibrations.
I have a layer of Tyvek to add to the sides before I slap the Coroplast back on. I should be able to reuse the old Coroplast sides without too many issues.
I built a new rear bulkhead and will try flush mounting the rear tail lights.
Dark Aero-The world's first aerodynamic single wheel boat tail!
