Old 11-12-2014, 10:14 AM   #20 (permalink)
0xsergy
Originally Posted by dirtydave View Post
Can you explain why the AC fan and the kill switch are connected?
You are keeping the AC fan on so you can use a kill switch?
YEahh you shouldnt do it like that....
You are increasing warm up time!!
You are using a huge electrical load!!
read the
65+ Vehicle modifications for better fuel economy - EcoModder.com
Nono. I keep fans + heat set to cold until the engine is at operating temp. I was using the empty AC fuse slot(I have no AC) to get hot power to route through the switch and over to the relay. I fixed that. I bought a dual fuse thingy which I have in the fuse slot for cig and radio that I'm running a 5a fuse in for my 12v->5v dc converter(for dashcam) and the kill switch.
@Daox Taking into account I had two tanks at 4.87 and 4.93 that's a pretty decent difference. Or maybe I'm looking too far into patterns that aren't there.
EDIT: Did the PS delete just now, removed the belt(lazy method, i know). I took it for a test drive to see if looping the system/etc would be worth the effort but it's so easy to turn. I'm a small guy, 130lbs 5'7", so not exactly Hercules but I had no issues in turning the wheel with one hand at red light right turn speeds which was my main concern. If I do find a low KM version of my car I'll grab a steering rack out of an automatic coupe(that's the version that came with manual steering) and drop that in. For this mileage though it's not worth the money/time.
