Old 11-12-2014, 06:42 PM   #110 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
voltmeter "eco cam" indicator tested!
Cool beans! I just saw the economy cam profile in action.
The electrical connector for the economy VTEC actuator is easily accessible behind the right side of the valve cover. So I connected my voltmeter to the connector's black wire with white stripe (positive) and to ground and went out for a short drive.
Observations:
  • The eco cam profile is only active in 3rd, 4th & 5th gears
  • Coolant temp must be over 145 F (edit added Nov. 23)
  • It remains active through gear changes (upshifts)
  • I saw it working as low as 1000 RPM
  • It de-activates under deceleration fuel cut-off (DFCO)
  • It stays active up to relatively high engine load -- with gradual throttle application -- up to ~65% load, according to the ScanGauge.
  • This VTEC transition is much more subtle than the lean burn transition in my 2000 Insight. I played a little game where, without looking at the voltmeter/indicator, I tried to guess whether I could feel the in/out transitions and missed a bunch of them.
  • I wasn't able to see the MPG difference on / off the eco cam lobes, because I wasn't driving on a flat road. Maybe a subject for a future test.
I may just have to dig up an LED and make myself an eco light.
The Following 3 Users Say Thank You to MetroMPG For This Useful Post:
Daox (11-13-2014), mikeyjd (01-15-2015), PaleMelanesian (11-13-2014)
