Old 11-13-2014, 01:07 AM   #6905 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
I think you need to select the dspic30f4011 device. Maybe a different microcontroller is selected. I'm on my phone, but will be on the computer later
The yellow dot on the board (closest pin to you) goes with the pin that has the triangle. The 6th pin is unused. Verify that the dspic30f4011 is loaded:
Go to
Configure->Select Device...
Then in the box that says "Device:", select dapic30f4011.
Also, to load the hex file, go to
File->Import...
And select the hex file.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
duncan (11-13-2014)
