Originally Posted by anox195
Ill be using 2 1 quart tanks, each will be cleaned and refilled with distilled water every 2 months...
This is my point exactly! You will be using a total of 2 quarts of water in the tanks. The actual "usable" amount of water will be much less than that because the electrodes have to stay mostly covered in water to work efficiently...so optimistically assume that you will use a pint of water before you have to refill. You also mention you're only going to change the water every 2 months. The amount of hydrogen produced from a pint of water is incredibly minimal. If you do the research, do the math, learn the chemistry, you would have to use close to a pint of water per DAY, not per 2-MONTHS to see any noticable increase in your mpg. Once again, do the research, look up how much hydrogen you get per volume of water, and you'll soon see that the numbers don't add up.
