Old 11-18-2014, 07:14 PM   #1337 (permalink)
freebeard
This ones really cool!
That is wild!
Agreed. I know someone sitting on a 4-passenger low-wing fuselage with the same intent.
It could be improved, by pie-cutting the lower rear door to roll the sill upward and inward, even a little. Also the contour goes all wobbly. If it had a curved tube to define the upper edge, it would be easier maintain the contour in an aerodynamically critical area. One could even drop the edge to help with ingress/egress.
See? It's easy to be a critic!
Edit: While I felt bad about putting that 2CV rat in the thread at #1333, I feel better about this one. The fit & finish and the lines are better:
http://flickrhivemind.net/Tags/ami,ami6/Interesting
I'd like it stretched a little through the doors, but at least it has them. The rat has a flip-up top.
Last edited by freebeard; 11-19-2014 at 02:34 AM.. Reason: ...new info has come to light, man!
