Thread: Nissan Leaf
Old 11-19-2014, 06:05 PM   #109 (permalink)
undeRGRound
undeRGRound's Avatar
Then there is the small matter of the cost of the Level 3 EVSE - they are apparently $10,000-12,000. I think the Leaf's Level 3 is ~44kW.
That one could prolly run off a regular residential service, and using it at night could result in an off-peak kW rate? If the input voltage requirements are in line with your service. Adding a transformer would be expensive
Even for a DIY install. But I bet MA has a strict licensing/bonding requirement
