Old 11-21-2014, 02:51 PM   #327 (permalink)
BamZipPow
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Wink
SCUBA tanks are pumped to 1500psi, a little one of those would last, what, months?
At a car show I saw a mid-engined Karmann-Ghia that had an air-shifter system that used SCUBA tanks. He said he could shift the car for a month on one refill.
I'll keep that in mind but I'm really leaning towards an on-board air compressor that can do it all (shocks, air bag, tires, etc).
I did find out that I have to take the weight off the air bag in order to inflate it because it doesn't have enough power to lift the trailer up when it's loaded.
I've calculated the size of the bottom gap cover to be 66" wide x 16" long. I'll probably fold some ears on it so it won't tin can while it's in use. I have some galvanized metal from some duct work that I'll try to use. I know I have a ton more work to reduce the amount of air the trailer is scooping from the truck.
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following User Says Thank You to BamZipPow For This Useful Post:
aerohead (11-21-2014)
