does anyone have a part number for the 5-wire wide band LAF sensor in the 1992 VX. It looks like I may have one in the car I just got. Interested in putting in an ECU. If I do have the 5-wire wide band LAF sensor, is it just a straight ECU Swap or do I need to do anything programmatical?
Also, do you think I can pass smog in CA with the federal ECU or just swap the ECU out to pass smog every time I need to handle the bi annual CA smog test.
