Old 11-24-2013, 08:04 PM   #71 (permalink)
Just finished building my harness!
Old 11-25-2013, 03:41 PM   #72 (permalink)
NightKnight
NachtRitter's Avatar
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 54.39 mpg (US)
Mathilde - '99 Volkswagen Eurovan Camper
90 day: 16.87 mpg (US)
Wow! Looks very nice; great gob!
Old 11-25-2013, 08:27 PM   #73 (permalink)
Got the new harness installed....
I plugged it all in, then the car wouldn't start!!! I was like "awwwww crap!"
Then I tightened down my ground wire...
Everything's running fine, no check engine light on or any other noticeable problems!
I guess the next thing to do is finding out how to monitor lean burn? I thought there was a dash console that had a lean burn light?
Old 11-27-2013, 11:39 AM   #74 (permalink)
DOFZO's Avatar
SLOMOTO - '92 Honda Civic VX
90 day: 56.49 mpg (US)
On the 49 states version there is a green shift up light on the gauge cluster that illuminates when it's time to shift gears to maintain the best fuel economy.
Here's the best picture I could find on the net:
The MPGuino is also a good way to monitor fuel economy.
MPGuino trip computer - MPGuino
ZO.
Old 11-27-2013, 12:06 PM   #75 (permalink)
ZO.
I have an extra console like that from my parts car, but it's got an extra plug in the back that I don't have a wire for. Even if it tells you when to shift, does it let you know if you're in lean burn?
Old 11-27-2013, 12:44 PM   #76 (permalink)
DOFZO's Avatar
There's nothing that indicates lean burn mode. I've read threads where people think they can feel lean burn, but that's it. The MPGuino is a good option and provides a direct read out of MPG.
I've switched the instrument wire harness once, but with another 49/S VX so I'm not sure where the extra plug goes. If you can post a pic of the back of your cluster I can take a look at the one I have.
ZO.
Old 11-27-2013, 12:54 PM   #77 (permalink)
after driving at highway speeds yesterday, I could also feel lean burn mode. I could especially feel it coming out of lean burn if I gave it a little more gas. I noticed someone on this board called it their "butt sensor" cause that's how they monitored lean burn
The cluster I have with the shift light has a plug near the yellow plug that is approximately the same size as the yellow plug. I'll get a pic of it a little bit later.
Old 08-05-2014, 07:50 PM   #78 (permalink)
NachtRitter Thank you for your efforts. I'd contacted you last November for the wire diagram of the 8 wire plug and you helped. I have had all the components since then but just decided to install it now.
Well it works as of today and I will be taking a 900 mile trip tomorrow to see if the mpg is better.
Old 11-22-2014, 07:08 PM   #79 (permalink)
EcoModding Newbie Girl
Ecovox - '92 Honda Civic VX
90 day: 30.44 mpg (US)
The Dragon - '01 Dodge Ram 3500 Laramie SLT
does anyone have a part number for the 5-wire wide band LAF sensor in the 1992 VX. It looks like I may have one in the car I just got. Interested in putting in an ECU. If I do have the 5-wire wide band LAF sensor, is it just a straight ECU Swap or do I need to do anything programmatical?
Also, do you think I can pass smog in CA with the federal ECU or just swap the ECU out to pass smog every time I need to handle the bi annual CA smog test.
Old 11-22-2014, 08:47 PM   #80 (permalink)
bluesteel93's Avatar
Turtle - '94 Honda Civic VX
90 day: 48.37 mpg (US)
SVO - '86 Ford Mustang SVO
Team Turbocharged!
90 day: 22.03 mpg (US)
Not sure on the part number but as long as its a 5-wire and not a 4-wire you should be good to just swap ecu's. If the o2 is bad after you swap ecu's this seems to be the best replacement for the price Amazon.com: NGK 24300 Oxygen Sensor - NGK/NTK Packaging: Automotive
The Following User Says Thank You to bluesteel93 For This Useful Post:
leety (11-22-2014)
5-wire o2 sensor, ca to fed conversion, civic vx
lean burn rules~! coolwHip Introductions 42 10-01-2011 06:42 AM
Civic VX VIN Info TomO Off-Topic Tech 5 12-07-2010 03:52 PM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 01:39 PM
Craigslist Milwaukee: '97 Civic HX lean burn love MetroMPG For Sale 0 02-05-2009 05:02 PM
VX lean burn Nden DIY / How-to 11 12-05-2008 10:01 AM
