Old 11-22-2014, 11:42 PM   #12 (permalink)
niky
Originally Posted by leety View Post
I'm working with a 1992 Honda Civic VX, working on deferred maintenance issues first. I'm get all the systems in a serviceable state. While I work on those matters, I'm researching some of the fun things I can do next ;-)
Down here, people modify P05 ECUs to achieve programmability with mid-90's Civics for much less money than an actual programmable ECU. I have no idea how much junkyard ECUs are in your area, and where you would have to go for the modification.
You could also look for a secondhand APEXi S-AFC... which allows very crude fuel map alterations for your car.
After that, there are more modern air fuel controllers, but they obviously cost more.
The Following User Says Thank You to niky For This Useful Post:
leety (11-23-2014)
