Originally Posted by RustyLugNut
Those are very well known branches of science and you have ignored them in your searches.
If you feel it is a dead end, then why don't you drop out of the conversation. If you just want to heap your Google research on the subject, I can't stop you. But why don't you put into Google "ozone 40ppm combustion" and see a link to Reasearchgate and download a pdf from the SAE on how small amounts of ozone measurably affect combustion.
MY searches! YOU are responsible to back up your claims, not I.
Yup, I found the PDF you are referring to:
http://www.researchgate.net/profile/...586dacfb000000
Check it out.
Notice the used engine type (
Homogeneous charge compression ignition - Wikipedia, the free encyclopedia).
Notice the conditions under which the ozone affects the combustion.
Our engines do not run pure iso-octane at 200°C (382°F) intake temp at over 30 bar (420 PSI).
I understand the reasons why they did so, and I can imagine there can be a benefit from seeding ozone into a regular engine.
But regular engines don't suffer from the problems that HCCI engines encounter, neither could they ever approach the efficiency of a well running HCCI engine no matter what you put in the intake.
Better keep civil and tone down. Remember real experts never boast their knowledge.
