Old 11-28-2014, 05:59 PM   #216 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by bluesteel93 View Post
According to tire rack the re92's are only 13lbs versus the michelins being 17lbs! That means any weight advantage the vx wheels have over the hx wheels doesn't really matter based on these wheel choices. It would be interesting to test... I'm not too far from you wolf (Orange County), maybe once my vx is running good we can test this. I was planning on getting a set of the michelins for my vx wheels anyway.
http://www.tirerack.com/tires/tires....=yes&tab=Specs
http://www.tirerack.com/tires/tires....num=665SR4RE92
Wow. I did not ever notice the weight difference. Compared to the 13" Defenders, the 14" RE92s are not only 4lbs lighter, they are also 10mm thinner. And the RE92s are cheaper at the moment, by $24 for the set of four right now. But the UTQG rating of the RE92s (260) is less than a third of the Defenders (820). That could mean you'll need three times as many RE92s to go the same distance the Defenders will go. That's a rate of an extra $600 for the same distance treadwear. In terms of cash it's probably the defenders that save you money.
And hey, I am in Orange County too. Down near San Clemente. Still love the idea of a Southern Cali meetup somewhere.
