Old 11-29-2014, 10:06 AM   #26 (permalink)
Ecky
90 day: 39.72 mpg (US)
90 day: 58.66 mpg (US)
Even if there is, you'll need to adapt it to the plug I put on my charger. Installation is easy enough (IMO) that you're probably best off just using the harness I provided.
EDIT: When you run the harness out of the battery box, I suggest wrapping electrical tape around the wires a few times to prevent chafing.
