Old 12-01-2014, 11:16 AM   #156 (permalink)
MetroMPG
90 day: 57.73 mpg (US)
LED eco cam indicator in action!
Originally Posted by xavi View Post
You should try your led with 4-5 volts before mount it, as it is the power that goes to the solenoid... It may not light enough to notice behind the dash.
I checked my wiring first with the voltmeter, and the wire carried full voltage (~14 v) when the solenoid is active.
Here it is!
Wasting fuel ... (LED is just above the temp gauge)
Wasting less fuel ...
The LED is attached to a thin strip of origami'd metal stuck into the gap between the upper dash (grey) and black bezel surround of the gauge cluster.
In those 2 pics, you see that passing the 1000 RPM threshold under light load activates the light.
ID:	16526   Click image for larger version
ID:	16527   Click image for larger version
The Following 3 Users Say Thank You to MetroMPG For This Useful Post:
j12piprius (12-23-2014), PaleMelanesian (12-02-2014), Sven7 (12-01-2014)
