This isn't a very good picture because the car isn't sitting on flat ground, isn't pointing against a flat wall, and you can't see that the projectors are sending their light almost perfectly parallel to the ground, but it's the best I have until I can do some fine tuning:
Here's how it was before, when I had the lights pointed down to prevent blinding other drivers. Notice the uneven distribution of light, and how it peaks in the middle of each beam:
Compare it to the left side of this picture and you can see roughly where the light is going:
