Old 12-03-2014, 04:40 PM   #323 (permalink)
The donkey CRX
The donkey CRX's Avatar
MULE VX - '92 Honda civic VX
90 day: 92.6 mpg (US)
White 94 VX "Show Car" - '94 Honda Civic VX VX
90 day: 79.92 mpg (US)
The Walrus - '02 Honda Insight base
Gen-1 Insights
90 day: 100.88 mpg (US)
Ha! OG, you are probably right!! Actually that's why I labeled most of the wires, even I can't remember what some of them are for.
I am also going to need a few permanent "cheat sheets" posted under the hood and in the "cockpit" to get the "pre-flight" procedures all done and in the correct order before takeoff!!!
According to the MPGuino I did 86 MPG going into the shop this morning (temp of 41 degrees), then it started raining and with a northeast headwind I was only able to do 79 MPG coming home (temp 47 degrees). I guess even with these mods I will still be subject to the variable winter weather. But there is no way I would have gotten close to these numbers without the pre-heat and alternator delete. I had to use the headlights both ways.
