Old 12-05-2014, 02:29 AM   #1831 (permalink)
Madact
Emerald - '97 Honda Civic CXi
90 day: 40.13 mpg (US)
YKYAEM if:
* You see a prius tucked in behind an 18 wheeler pull out, just so that it can overtake at about 5kph / less than walking speed faster than the truck, and think "fool!".
* You've worked out that on a commute including 25km of freeway, the difference between 90kph and 110kph would only 'save' you 3 minutes... and even then only if traffic would allow you to do exactly 110kph the whole way, which is unlikely.
* You see mechanical failures on a new-to-you car not so much as an inconvenience as a good excuse to upgrade by swapping in more mpg-friendly parts.
