Old 12-06-2014, 09:54 PM   #11 (permalink)
Madact
Emerald - '97 Honda Civic CXi
90 day: 40.13 mpg (US)
Originally Posted by vrmouseyd15b View Post
MADACT - is your d16 block lean burn ready?
Ah... is the block lean burn ready? unsure - I know I'm going to need an EGR intake manifold and an appropriate ECU, but I was under the impression that the block & pistons didn't need anything special for lean-burn. Is this incorrect?
are you going to run a manual tranny? Sounds like fun! Please share some pics of your head, I'm curious. What is the code on it and year stamped? P2J?
Manual, naturally - this is ecomodder.com after all
The code is "P2J-1", year code 96 (had a fun time finding it, the engine this came off was evidently throwing oil like it was going out of fashion), intake side has a "1" in a square, there's also a "4" and "15" stamped near the coolant outlet.
I've put pics up in this thread:
http://ecomodder.com/forum/showthrea...tml#post458601
I'm 3 stage vtec on the minion, and would love to see and hear about more 3 stagers out there! Any help I can offer, just ask. Feel free to p.m. me. I've got a few wiring references, and some hard learned tricks as well!
Edit: what ecu do you plan on running?
Any help would be much appreciated! Best place for it would be on the thread linked above. I have just received a P2J-003 ECU, and I have an OBD2A D16Y8 wiring harness on the way, which I was advised would be the simplest to modify. Still looking for a D16Y5 intake manifold to enable EGR - I understand lean-burn with no EGR would be a Bad Thing...
I've heard OBD2 ECUs can't be 'tuned', but I'm planning to run stock-as-a-rock (well, apart from being a complete frankenstien of course, what with the D16 block and all ), so I'm hoping I can keep all the parameters where the ECU wants them by careful selection of injectors and/or fuel pressure.
