I would spring for the scangauge. If you deal with numbers, a bad number glaring back at you is great motivation to improve. Try to time all signal lights, it saves time AND fuel. Your mood also improves the fewer times you have to come to a stop. When you are ticked off you wont drive efficient. See the connection there?
